Installing Unity Express on an ISM-SRE-300-K9
James Hawkins
Level 8
Level 8
A colleague of mine has a 2921 router with an ISM-SRE-300-K9 service module which will run Unity Express.
When he tries to enable the service module using the service-module enable the router displays the message below:
Memory size doesn’t meet the requirement of Embedded-Service-Engine 0/0
Does anyone know what memory this refers to? - the 2921 router has 512MB DRAM and 256MB flash.
If someone can answer this and ideally provide a link to a Cisco document stating the requirements I would be very grateful.
gnanem
The requirement of the DRAM to run an embedded service engine is 1 GB. Please find the link for the same:-
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/cimce/1.0/configuration/guide/CIMCe.html#wp1104930
Gnaneswaran.
-pls rate helpful posts...
