installing vic2-4fxo on a mgcp Voice gateway
baselzind
Level 6
Level 6
i need to install vic2-4fxo on a mgcp analog voice gateway , im wondering is there certain commands i need to configure to allow the voice card to function for the first time like the case in H.323 digital voice gateway ? or are all the configuration get pulled from the cucm gateway configuration page?
Manish Gogna
This card should be configured on the gateway configuration page on CUCM followed by a rest of gateway and then you can do a no mgcp / mgcp on gateway. Provided the 'ccm-manager config server' is configured on the gateway it will pull the config from cucm.
Manish
Manish Gogna
Manish
for example are these configuration taken from my old mgcp gw are also pulled from cucm? or configured directly on the router?
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone mytone
no comfort-noise
timeouts call-disconnect 1
timeouts wait-release 1
dial-peer voice 1 pots
service mgcpapp
port 0/0/0
The pots dial-peers are created automatically for the MGCP FXO ports and other mgcp related config is also pushed via the xml file from cucm.
You can check this video detailing the process of adding analog ports on MGCP
https://www.youtube.com/watch?v=34nWvm0qI3g
Manish
