Instructing CUCM to call you
alialjamri2008
Is there a way to ring extension number and then the extension will make/initiate CUCM call to your phone?
Ali
7 Replies 7
Anas Abueideh
Level 9
Level 9
you are talking about single number reach. you to configure it.
or in simple way you can forward all your calls to your mobile.
Anas
please rate if it is helpful
Sent from Cisco Technical Support Android App
Amit23
Level 4
Level 4
right...
you can confiugure single number reach..
use below links for more help:
http://www.youtube.com/watch?v=cqfjaiySiUs
http://www.cisco.com/en/US/docs/voice_ip_comm/hucs/7.1a/provision/CH13_HUCS.pdf
Warm Regard's
Amit
Warm Regard's
Amit Sahrma
Sorry guys, I know about this mobility option. My case qustion is to instruct the cucm to call your mobile and let the cisco unity or other call handler to allow you to select and dial extension number from inside.
The call will be charged as regular outside call for the cucm, while I am not making any call from my phone/cell. So my qustion is to dial and ring an outside cucm number, and then end the call from my cell phone. Then the cucm will make a call to my cell number, is this possible?
Ali
I doudbt if could be possible just running CUCM and CUC at least with out a thirdparty application.
This could be possible done running UCCX. Check this information:
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/index.html
Please rate all useful posts
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice, CCNP Voice Certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
No way to do that with CUCM and CUC, the closest thing are the mobility options and/or use a jabber client.
java
if this helps, please rate
And how to achieve this using Jabber client?
You cannot achive exactly what you want just running Jabber but it works like a softphone using the cellphone's internet connection to register to Call Manager so you will be able to make a phone call just using a 3G or WiFi connection.
