08-06-2015 06:28 AM - edited 03-17-2019 03:54 AM
Hello everyone
When I log into our CUCM we receive the following msg ( Picture 1), We have checked CUC ELM and found ( Picture 2, 3 ), why were the licenses expired and on what bases were they installed. Is it trial or something wrong from the beginning
14 February Logs
2015-02-14 00:39:27,053 INFO [PC] ElmMgr - License Analysis starting ...
2015-02-14 00:39:27,072 INFO [PC] DbHelper - Performed DB change: UPDATE SystemData SET ElmId = '40de26a663af43b8b033f03eaae096fd', SyncInProgress = 1, Status = 2 WHERE ObjectId = '44070ef8-4aed-489e-b157-236ab52c66b5' Returns: 1
2015-02-14 00:39:27,078 INFO [PC] FneBaseLSI - Get list of features returns 6 feature(s)
2015-02-14 00:39:27,078 INFO [PC] LicSource - Loaded 6 license tags from LSI FNE.
2015-02-14 00:39:27,079 INFO [PC] LicSource - Entitle: CUC_CUWLProfessionalMessaging:9.0 - Cnt=20, Exp=Sun Feb 15 23:59:59 GMT-02:00 2015, ExpSoon=true, Expired=false
2015-02-14 00:39:27,079 INFO [PC] LicSource - Entitle: CUC_CUWLStandardMessaging:9.0 - Cnt=25, Exp=null, ExpSoon=false, Expired=false
2015-02-14 00:39:27,079 INFO [PC] LicSource - Entitle: CUC_SpeechConnectPort:9.0 - Cnt=2, Exp=null, ExpSoon=false, Expired=false
2015-02-14 00:39:27,079 INFO [PC] LicSource - Entitle: UCM_CUWLProfessional:9.0 - Cnt=20, Exp=Sun Feb 15 23:59:59 GMT-02:00 2015, ExpSoon=true, Expired=false
2015-02-14 00:39:27,080 INFO [PC] LicSource - Entitle: UCM_CUWLStandard:9.0 - Cnt=25, Exp=null, ExpSoon=false, Expired=false
2015-02-14 00:39:27,080 INFO [PC] LicSource - Entitle: UCM_TelepresenceRoom:9.0 - Cnt=5, Exp=Sun Feb 15 23:59:59 GMT-02:00 2015, ExpSoon=true, Expired=false
Log of 16 February 2015,
2015-02-16 00:40:00,567 INFO [PC] ElmMgr - License Analysis starting ...
2015-02-16 00:40:00,578 INFO [PC] DbHelper - Performed DB change: UPDATE SystemData SET ElmId = '40de26a663af43b8b033f03eaae096fd', SyncInProgress = 1, Status = 2 WHERE ObjectId = '44070ef8-4aed-489e-b157-236ab52c66b5' Returns: 1
2015-02-16 00:40:00,584 INFO [PC] FneBaseLSI - Get list of features returns 6 feature(s)
2015-02-16 00:40:00,584 INFO [PC] LicSource - Loaded 6 license tags from LSI FNE.
2015-02-16 00:40:00,584 INFO [PC] LicSource - Entitle: CUC_CUWLProfessionalMessaging:9.0 - Cnt=20, Exp=Sun Feb 15 23:59:59 GMT-02:00 2015, ExpSoon=false, Expired=true
2015-02-16 00:40:00,585 INFO [PC] LicSource - Entitle: CUC_CUWLStandardMessaging:9.0 - Cnt=25, Exp=null, ExpSoon=false, Expired=false
2015-02-16 00:40:00,585 INFO [PC] LicSource - Entitle: CUC_SpeechConnectPort:9.0 - Cnt=2, Exp=null, ExpSoon=false, Expired=false
2015-02-16 00:40:00,585 INFO [PC] LicSource - Entitle: UCM_CUWLProfessional:9.0 - Cnt=20, Exp=Sun Feb 15 23:59:59 GMT-02:00 2015, ExpSoon=false, Expired=true
2015-02-16 00:40:00,585 INFO [PC] LicSource - Entitle: UCM_CUWLStandard:9.0 - Cnt=25, Exp=null, ExpSoon=false, Expired=false
2015-02-16 00:40:00,586 INFO [PC] LicSource - Entitle: UCM_TelepresenceRoom:9.0 - Cnt=5, Exp=Sun Feb 15 23:59:59 GMT-02:00 2015, ExpSoon=false, Expired=true
Many thanks for any suggestion
08-06-2015 07:01 AM
You are over in your licensing as the images suggest. You are borrowing the needed licensing from upper tier but even then, there are not enough licenses. Either remove the devices or add more licensing.
08-06-2015 08:19 PM
you have 25 CUWL standard licenses installed which have been loaned to Basic (19)/ Essentia(2) and Enhanced [18] which makes the total count as 39. So, u are running short of 14 licenses .
the same is showing as RED or Insufficient licenses in picture 2 attached snapshot.
Also, CUWL Standard supports Voice mail license by default. Hence, the same is also showing as installed under CUWL Standard messaging [25]
In short, u need to buy either CUWL Standard licenses if messaging in needed else but buy as "required" as showin in snapshot.
regds,
aman
08-08-2015 12:09 AM
Thanks for your answer.
Please check my last edit on the case.
08-12-2015 02:51 AM
the 25 license are probably the be6k/be6s starter bundle.
you have 39 endpoint but how the and point are distributed among the users?
Remeber that the new licensing model is "user-based" and not and "point-based"
Cuwl license can include up to 10 endpoint for user (http://www.cisco.com/c/dam/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/116231-technote-cucm-08.png)
to let the sistem (CUCM and PLM) know the device ownership you need to configure the "Owner user ID" under in the device configuration
For example:
18 user with a basic phone (7821) + jabber (windows/mac/iphone/ipad/android) (36 endpoint)
1 user with a phone (1 endpoint)
2 fax machine (2 endpoint)
in this scenario are licensed:
18 ENH+ (upper tier CUWL standard)
1 BAS (upper tier CUWL standard)
2 ESS (upper tier CUWL standard)
total 22 CUWL standard license
rate if help
Sandro
08-06-2015 01:39 PM
You must be using Demo licenses. I've never heard of someone buying a CUCM for only 25 users. That would be more of a CME deployment.
