Integrate CUCM with BE6000(CCX)
ievalleyccie
Can I deploy CUCM on a separate server and integrate it with the CCX which is come with the BE6000 ?
Jaime Valencia
Yes, but then we won't consider that deployment a CUCMBE 6K
It'll be a regular CUCM / UCCX deployment.
BE6K means you'll install the apps in the same server using the 6K OVAs and integrate them, and if necessary, add another 6K server for redundancy.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
If I used the 6K OVAs and installed the CUCM and CCX and I use that CCX to integrate it with another CUCM ?
Can I integrate CCX 9.X with CUCM8.6 ?
Yes, you can integrate  UCCX 9.X with CUCM 8.6. You can use this link as a reference:
Link: http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
