02-07-2017 01:34 AM - edited 03-17-2019 09:26 AM
All, need information
I want to integrated system Paga to CUCM [10 or higher] , Paga be equipped PC Call Server with SIP to connect another SPA/ATA .
On SIP menu PC Call Server there is no parameter with IP Add , only username ,
In this situation , Can CUCM integrated with Praesideo Telephone Interface [Paga] ?
Need your suggestion :)
Cheers,
SH
02-07-2017 02:12 AM
Did you check with Pags support if it has ever worked with CUCM through any type of integration?
Manish
02-07-2017 05:20 PM
@Manish
I dont have doc reference , and vendor has never been try connecting PA system to CUCM
10-15-2017 11:04 AM
10-15-2019 05:35 AM
hi solihul ,
Have you resolve the issue. i have to do the same
