Integration between asterisk and CUCM using QSIG
RAVIKUMAR J K
Hi All,
Hope someone can guide me.
I have a requirement to integrate CUCM and Asterisk using QSIG. (SIP Trunk option is ruled out)
Can someone guide how I can accomplish this ? some link or document or any info related will be very helpful.
You would need Gateway in between CUCM and Astreik to achieve this.
Call flow would be like this.
CUCM--SIP/H323--GW--QSIG--Asterisk
Balram
Please rate if you find this helpful
Thank You
Balram
Georgios Fotiadis
To add to the previous post, is your requirement to strictly use Q.SIG or not use a SIP trunk? If it is the first the @Balram Vishwakarma has answered you. Asterisk supports Q.SIG in the chan_dahdi module.
Though, if it the second you can simply use an H.323 trunk directly between CUCM and Asterisk (you should use chan_oh323 or chan_ooh323 for Asterisk).
Georgios
Please rate if you find this helpful.
