Not sure why you mentioned the expressways if all you want is to integrate Jabber with Outlook (not sure if you really meant Exchange?????)
You would probably need to clarify exactly what you want to do.
In any case, for Outlook, review the J4W docs
For Exchange, the IM&P config guides.
java
if this helps, please rate
