Integration CUCM 7 and Aastra BP 250
shabeebmohammed
Im planning to integrate CUCM with Aastra BP 250. This has not yet been tested and verified by Cisco. The customer is pushing me to do this. I was wondering if I will get any support from TAC in this regards since there is no information about BP250 in the Cisco site.
Also, Im planning on using H323 Trunking to go ahead with this implementation. Please give me your suggestions and feedback.
Shabeeb
5 Replies 5
Gajanan Pande
Shabeeb,
If the interoperability is not tested & documented by Cisco then it's safe to assume that such setup will not be supported by TAC. However if your customer is indeed interested in such interop testing, Cisco can conduct the testing for you & confirm. Please reach out to CAM team locally in your country & they will cascade you with the Interop team.
3rd party PBX interop with CUCM is documented here http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805b561d.html
HTH ?
GP.
Pls rate helpful posts.
Dear Gajanan Pande,
Thanks for the reply. Just wanted to pop in a question, what is CAM team and interop???
Shabeeb
Sorry, here you go with full forms
CAM : Channel Account Manager
Interop : Interoperability
Interop Team in Cisco does testing between third party products ( such as PBX etc ) with Cisco products ( e.g. CUCM, Gateway routers, Unity etc ).
GP.
Thanks GP
Will do that and let you know how it goes.
Sure.
Good Luck !!
GP.
