04-14-2019 11:29 PM
I am trying to call between two phones registered in two different CUCMs . I am trying to configure SIP trunk between the two CUCM, but the SIP status shows unknown -options ping not enabled. I followed steps to enabe options ping for sip profile, but when I try doing that i am getting error "Add Failed. One of the required feilds on page has same value as an entry that already exists in database. Please check the corresponding find List page to verify your entry does not exist.
CUCM Version -12.0.
Solved! Go to Solution.
04-15-2019 11:31 PM
04-16-2019 04:37 AM
You will need to copy the SIP profile and rename it to something else, since this error denotes that the SIP profile is already in use and cannot be manipulated.
04-14-2019 11:39 PM
Please try to check the concerned attribute. Also, please check the database replication from Publisher- utils dbreplication runtimestate. All tables must match and replication must be good(2).
You can also try to configure all profiles for this trunk to see the difference.
Vinod Dahiya
04-15-2019 11:31 PM
04-16-2019 04:37 AM
