204
Inter digit timeout on 7841
Is there a different setting to control the inter digit timeout when calling when the handset is off-hook and when it is on-hook?
If so what is the setting for each?
From
David Wood
1 REPLY 1
Nithin Eluvathingal
VIP Mentor
What RP you use ? a single RP for all calling  ?
When calling On hook its will be enbloc(if below parameter is enabled on 78XX phone page), the numbers will be send in a block. but when calling off hook, it send digit by digit and it waits T302 timer. Default value is 15 seconds you can reduce it if needed.
Response Signature
Create
Recognize Your Peers
Content for Community-Ad
