CleverDrake
Beginner
InterCluster Trunk between 7.1 and 6.1
We have a non-gatekeeper controlled trunk that we are having problems with. It works one way, but not the other. Is there any logs that I can look at on RTMT to give insight on this issue? We have narrowed it down to the trunk being the problem, but don't know what about the trunk is causing the issue.
2 REPLIES 2
Jaime Valencia
Hall of Fame Cisco Employee
CUCM detailed traces to find out what's wrong
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Rod.Blackie
Beginner
Did you resolve this issue? I have the same problem..
Rod
Content for Community-Ad
Spotlight Awards 2021
