07-16-2014 08:03 AM - edited 03-16-2019 11:25 PM
Hi to all,
somebody knows if I can configure a intercluster trunk (non-gatekeeper controlled) between an CUCM and an CME???
If the answer is yes, you can send me a link with this info??
Thank you so much.
David.
Solved! Go to Solution.
07-16-2014 09:01 AM
Depending on the version, you probably want to configure a SIP trunk or as an H323 GW, ICT is meant for CUCM clusters.
There's no doc outlining how to do this. On CME it's only the DPs pointing to CUCM, on CUCM the route pattern associated to the SIP trunk or H323 GW pointing to CME.
You should probably start by reading this
Interoperability of Unified CM and Unified CM Express
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/callpros.html#pgfId-1044453
07-16-2014 09:01 AM
07-17-2014 12:03 AM
Thanks Jaime!!
Now, I have got configured one SIP-T between the CUCM and CME, but, I don't know why, I only have one way audio and I would like to test this trunk type to try to have audio in the two ways.... My system is a lab system...
I will read this info and will test this.
Thanks for all.
David.
