Intercom extension the same as phone's extension in CUCM
kgilkes92
I have configured an intercom with the same number as the phone's extension indicated in the route plan report. Will this cause problems that I have to change the extension number of either the phone line or the intercom line?
Georgios Fotiadis
You will probably see in the Route Plan Report, that the intercom DN is in a differerent Partition. So, numbers are isolated and will not have a problem. Of-course you should grant access to these DNs using the appropriate CSSs.
Georgios
Please rate if you find this helpful.
