11-13-2012 10:22 AM - edited 03-16-2019 02:10 PM
I have configured INTERCOM in CUCM. After changing the button template to show the intercom in two 7961 phones and configure the directory numbers under the phone settings. I was unable to see the INTERCOM button on the screen of the 7961 phones. I made the same configuration on Cisco IP communicator and it works fine. Can anyone help me with this, please?
Frank
Solved! Go to Solution.
11-14-2012 06:09 AM
Hi Frank,
It's likely the phone firmware
The system requirements for the intercom feature follow:
•Cisco Unified Communications Manager Release 6.0
•Microsoft Internet Explorer (IE) 7 or Internet Explorer 8 or FireFox 3.x or Safari 4.x
•Cisco Unified IP Phones 8.3(1) or later
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fsintrcm.html#wp1047586
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
11-13-2012 11:46 AM
Hi Frank,
On the Intercom DN page, did you associate the Device?
Call Routing > Intercom >Intercom Directory Number
This doc is really good
https://supportforums.cisco.com/docs/DOC-4194
Cheers!
Rob
11-13-2012 11:59 AM
Yes, I have done the exact configuraiton on my IPC and the hardware phone, but still not working. The phone gets resetted after I made changes int he button template, but still I don't see the button on the screen. It seems when I find a problem is a real problem. I have another post tha has been seating for weeks and no answer. I hope you can help me with this.
Thank you Rob.
11-13-2012 12:13 PM
I just try adding a new BLF Speed dial and it is not showing on the phone buttons.either. I added a privacy button and it works fines. I can see it on the scren. Is there any specific service that controls those features?
regards,
Frank
11-13-2012 12:11 PM
Hi Frank,
Is it possible for you to send a screenshot of the Intercom
page for one or both of the configured phones?
It should show like below, with the associated device etc.
Cheers!
Rob
11-13-2012 12:17 PM
Intercom Directory Number Information
Second Phone
11-13-2012 12:29 PM
Hey Frank,
Looks good
Did you try doing a hard reset on the phones? Also have a look
at the Phone Button Template that you are using to see what line
position is assigned to Intercom.
Cheers!
Rob
11-13-2012 12:32 PM
Yes, I did a hard reset on the phone using 123456789*0# and the other code on one of the phones but it seems like nothing works. I also moved the key all the way to third or 4th possition. No luck.
Frank
11-13-2012 12:49 PM
Hey Frank,
I'm at a loss now Maybe it's a bug....what CUCM version
are you running?
Did you try stripping it all out and starting over?
Cheers!
Rob
11-13-2012 01:29 PM
System version: 8.6.2.20000-2
I am also using a firware on these phones that I found on the internet, because i don't have acess to download an original one from Cisco. Since is a study lab, I thought it would be fine, but now I am suspecting something is wrong with the firmware for those phones. What do you think?
11-13-2012 01:58 PM
Frank....could be phone firmware as well. Why don't you pass along that version number
as well.
Cheers!
Rob
11-13-2012 02:33 PM
7-6-26 is the one that is working for me. I downloaded 8.xxx and 9xxx. but they are not working it seems they are missing hte XMLDefault.cnf.xml file and some other files that the phone requests during TFTP image download.
12-18-2012 05:27 AM
I found out why a version newer8.3.5 will not work. For manual load of the firmware using tftpd32, you have to update firmware to 8.3.5 (for some reason, all others newer than 8.3.5 don't load) Once you have updated to 8.3.5 go ahead and load the latest version to CUCM TFTP server and the phone will download this newer version from CUCM. It seems that upgrading to 9.xxx using TFTPD32 is not supported with newer versions.
11-14-2012 06:09 AM
Hi Frank,
Cheers!
Rob
11-14-2012 06:17 AM
I am going to try to find this version and I will try it. thank you very much. I will post and rate once I have tried.
Frank
