Intercom question....
Ray Morehead
Our hospital is looking for a way to be able to page nurses via intercom, I know that CUCM does not support broadcast intercom which is what we need. I know (unless this has changed) that cucme supports broadcast intercom.
Heres my question: Since we already have CUCM running on our network, would it be possible or even a good idea to install CUCME in different departments to support broadcast intercom? I know that there are a lot of 3rd party vendors that have developed broadcast intercom, but I would prefer not having to install yet another piece of software.
~Ray
Hi Ray,
Hope all is well my friend
I just wanted to add my 2 cent$ to the good info from Java, Chris
& Michal (+5 each guys!)
If it were me, and you are running this in a Health Care environment
I would definitely go with more of an "Enterprise" solution. When the paging
requirement could be a life & death situation, I wouldn't want to have
the old "barbed wire & duct tape" type setup. Going with an enterprise
solution would allow broadcast paging, zone paging, overhead paging,
pushing "emergency" text to IP phones, etc. etc.
Here's three more;
Ipcelerate
http://ipcelerate.com/web/index.php/products-features/ipsession/paging
Syn-Apps
http://www.syn-apps.com/products/call-alert/
Singlewire
http://www.singlewire.com/informacast.html
As I say, this is just my 2 cent$ here Ray.
Cheers!
Rob
"Far away from your trouble and worry
You belong somewhere you feel free" - Tom Petty
6 Replies 6
Jaime Valencia
Assuming you want to have paging between the phones that are going to be registered to CME, yes.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Just found a post on this with your response Jaime, also found the CME integration guide.
I assume (at this point) that if I follow the integration guide....cucm will register cme....then the phones in the particalur department will register with that cme. I'll go read through the guide, and I'm sure I'll have a few more questions when done.
For now: would this integration work for wireless phones as well?
Thanks.
~Ray
If you upgrade your system to CUCM 9.1 you will receive free Singlewire InformaCast basic paging solution:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_1_1/CUCM_BK_R6F8DBD4_00_release-notes-for-cucm-91_chapter_0100.html
Not that it helps you now, but something to think about.
HTH,
Chris
grebac.2ring
Level 5
Level 5
Ray,
Have a look at our 2Ring PHONE SERVICES at www.2Ring.com/NewJuice - it provides paging + much more.
Michal
Hi Ray,
Here's three more;
Ipcelerate
Syn-Apps
Singlewire
Cheers!
Rob
Hi Rob,
Thanks for your input on this, its always appreciated.
I had a meeting with my boss yesterday on this and after the fact it occurred to me what you just said. So excellent point indeed. I scanned the websites that have been provided so I will be checking those out.
Although I am still curious about the cme to cucm integration so if nothing else, I will probably set this up in a lab just to test it at some point.
Thanks!
(I'll hold the change joke)
~Ray
