Intercom without auto answer?
victoriabardy
Level 4
Level 4
Does anyone here on the forum know if there is a way to set up intercom so that it beeps without auto answer?  Doesn't look like there is that option but wanted to double check.  We are running Call Manager 8.5.1.
Please let me know if you do.
Thank you.
Vicky
Joseph Martini
Nope no way to change intercom in CUCM to not auto answer.
singhaam007
Level 3
Level 3
Hi Victoria,
callmanager doesn't offer auto answer off like CME,
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
hotdial is another Alternative  you can use.
hope this helps.
please rate if this helps
thanks
