Highlighted
Beginner
Re: Interdigit Timeout with Legacy PBX via PRI
I haven't got any network-clock commands, should I configure these for the E1 port connected to the PSTN and the Legacy PBX? I do know that for data E1, one end must be clock-master and the other end clock-slave.
The output of "sh controllers e1" is:
E1 0/2/1 is up.
Applique type is Channelized E1 - balanced
Description: PSTN
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060711, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (318 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
10 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
10 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 9 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
244 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
244 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
E1 0/3/0 is up.
Description: PRI_ALCATEL_4200
No alarms detected.
272 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
272 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Highlighted
Hall of Fame Master
please configure
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 e1 0/2/1
this should eliminate the slips.
But I think you also need to provide clock to PBX, so configure clock source internal under controller E1 0/3/0.
Highlighted
Beginner
This seems to have cleared up the problem, thanks!
RE the IOS upgrade, I'm waiting for Cisco to register the SmartNET package as there seems to be a problem with registering the end user's address so the whole process is being taken care of by Cisco's helpdesk.
I'll let you know after I've upgraded the IOS.
Highlighted
Hall of Fame Master
Glad to know it helped.
you need to insist with cisco to get the registration done, sometime their system doesn't work and you have to call many times.
Highlighted
Beginner
Finally the SmartNET has been registered and I'm furiously searching the Cisco IOS Software Download to make heads or tails out of the never ending list of IOS versions!
At the moment we've got:
- CME 4.0.2(3)
- IOS 12.4(13r)T
We want to upgrade to:
- CME 4.2
- A higher IOS revision but as far as I can see, CME 4.2 is supported only in 12.4(11)XW2 or XW3
It seems that by upgrading to CME 4.2, I'll have to go down an IOS revision....can this be right?
Highlighted
Hall of Fame Master
You would actually loose only the features that are in 12.4(13)T but not in 12.4(11)T. For telephony, that means none.
If you really want CME 4.2, your only choice is 12.4(11)XW4.
Beginner
Yes, I thought so...for the 2821 its actually XW3 as XW4 seems to be for the UC520 and an 17xx series routers.
Where could I find some sort of changelog of telephony features for IOS versions? Navigating the IOS upgrade portal is sometimes frustrating as the information is very patchy.
Highlighted
Hall of Fame Master
You are right, XW4 has been released for the 1861 only for now.
The changelog you want is the IOS release notes. It lists the new features as bugs fixed.
Highlighted
Beginner
Yesterday I upgraded the software on the ISR 2821 to the following:
- IOS 12.4(11)T2 to 12.4(15)T1
- CME 4.0.3 to 4.1(0)
However, calls from the Legacy PBX to IP phones are still received without a Caller ID...
