11-26-2024 08:16 AM - edited 11-26-2024 08:23 AM
Hello ,
I am experiencing an issue with the Jabber application connected through Expressway. There are random disconnections occurring, and I notice the error in the Show connection status output. It briefly shows 'Not Connected' and then back to 'Connected automatically'
The CUCM version is 14.0.1.13900-155.
The version of expressway X14.3.6 .
Solved! Go to Solution.
11-26-2024 12:54 PM
In another post it was suggested that it helped to turn off STUN keepalives in Expressway.
11-26-2024 09:57 AM
Are your Expressway C added in CM in FQDN format? If not go into the menu for Expressway C in CM under Devices and make a copy of the existing C’s or edit the current C items and then do a refresh of CMs in Expressway C. That will add them back into CM with host name, but will not touch the once you set FQDN on.
11-26-2024 11:37 AM
Our Expressway C is already configured in FQDN format in the CUCM . Do you have any other suggestions to resolve the disconnection issues we're experiencing?
11-26-2024 12:54 PM
11-27-2024 04:00 AM
The change resolved the issue.
11-26-2024 12:56 PM
