1650
Hilal Computers
Beginner
Intermittent DTMF issue with CME Autoattendant message
Dear All,
I have an intermittent DTMF issue with one of my auto attendant message. Sometimes DTMF is passing through and reaching the extension numbers and other times its not passing.
ISP--> FXO--> CUE
As mentioned above, calls reaching to analog line card and then pointed to autoattendant number. I have another autoattendant configured on the same cme with different provider, which is working perfectly without any issues. Both provider(PSTN) analog lines configured with same parameters.
I have tried to trace the DTMF failed call and the output is like below,
Jul 12 10:46:25.595: //-1/A9927CBC8285/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=36558521
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4445
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jul 12 10:46:25.595: //-1/A9927CBC8285/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2B73DD3C, Call Info(
   Calling Number=36558521,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4445(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=02, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jul 12 10:46:25.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 10:46:25.599: :cc_get_feature_vsa malloc success
Jul 12 10:46:25.599: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 10:46:25.599:  cc_get_feature_vsa count is 1
Jul 12 10:46:25.599: :FEATURE_VSA attributes are: feature_name:0,feature_time:719954792,feature_id:310
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=36558521(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4445(TON=Unknown, NPI=Unknown))
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/cc_process_call_setup_ind:
   Event=0x313318F8
Jul 12 10:46:25.599: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4445
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/ccCallSetContext:
   Context=0x3258DA30
   >>>>CCAPI handed cid 268 with tag 0 to app "_ManagedAppProcess_Default"
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=4445, Params=0x32593EF8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/ccCheckClipClir:
   In: Calling Number=36558521(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=36558521(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=4445, Called Number=4445, Digit Strip=FALSE
   Redirect Number=, Display Info=36558521
   Account Number=, Final Destination Flag=TRUE,
   Guid=A9927CBC-CB45-11E1-8285-BB9E0D883FB6, Outgoing Dial-peer=4445
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=36558521
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4445
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B312EA8, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=36558521,(Calling Name=36558521)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4445(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=4445, Call Count On=FALSE,
   Source Trkgrp Route Label=02, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Jul 12 10:46:25.599:  cc_get_feature_vsa count is 2
Jul 12 10:46:25.599: :FEATURE_VSA attributes are: feature_name:0,feature_time:719956584,feature_id:311
Jul 12 10:46:25.599: //269/A9927CBC8285/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Jul 12 10:46:25.599: //269/A9927CBC8285/CCAPI/ccCallSetContext:
   Context=0x32593EA8
Jul 12 10:46:25.599: //268/A9927CBC8285/CCAPI/ccSaveDialpeerTag:
Jul 12 10:46:25.603: //269/A9927CBC8285/CCAPI/cc_api_call_proceeding:
   Interface=0x2B312EA8, Progress Indication=NULL(0)
Jul 12 10:46:25.623: //269/A9927CBC8285/CCAPI/cc_api_call_alert:
   Interface=0x2B312EA8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jul 12 10:46:25.623: //268/A9927CBC8285/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jul 12 10:46:25.643: //269/A9927CBC8285/CCAPI/cc_api_call_connected:
   Interface=0x2B312EA8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 12 10:46:25.643: //268/A9927CBC8285/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=268
Jul 12 10:46:25.643: //268/A9927CBC8285/CCAPI/ccConferenceCreate:
   (confID=0x2D1DFFDC, callID1=0x10C, gcid=A9927CBC-CB4511E1-8285BB9E-D883FB6, tag=0x0)
Jul 12 10:46:25.643: //269/A9927CBC8285/CCAPI/ccConferenceCreate:
   (confID=0x2D1DFFDC, callID2=0x10D, gcid=A9927CBC-CB4511E1-8285BB9E-D883FB6, tag=0x0)
   Conference Id=0x2D1DFFDC, Call Id1=268, Call Id2=269, Tag=0x0
Jul 12 10:46:25.643: //268/A9927CBC8285/CCAPI/cc_api_bridge_done:
   Conference Id=0x34, Source Interface=0x2B73DD3C, Source Call Id=268,
   Destination Call Id=269, Disposition=0x0, Tag=0xFFFFFFFF
Jul 12 10:46:25.643: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jul 12 10:46:25.643: cc_api_get_xcode_stream : 4702
Jul 12 10:46:25.643: //269/A9927CBC8285/CCAPI/cc_api_bridge_done:
   Conference Id=0x34, Source Interface=0x2B312EA8, Source Call Id=269,
   Destination Call Id=268, Disposition=0x0, Tag=0x0
Jul 12 10:46:25.647: //268/A9927CBC8285/CCAPI/cc_generic_bridge_done:
Jul 12 10:46:25.647: //268/A9927CBC8285/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x34, Destination Call Id=269)
Jul 12 10:46:25.647: //269/A9927CBC8285/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x34, Destination Call Id=268)
Jul 12 10:46:25.647: //268/A9927CBC8285/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2B312EA8, Destination Call Id=269, Source Call Id=268,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jul 12 10:46:25.647: //269/A9927CBC8285/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2B73DD3C, Destination Call Id=268, Source Call Id=269,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Jul 12 10:46:25.647: //269/A9927CBC8285/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8653)
Jul 12 10:46:25.647: //268/A9927CBC8285/CCAPI/cc_api_caps_ack:
Jul 12 10:46:25.647: //268/A9927CBC8285/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Jul 12 10:46:25.647: //268/A9927CBC8285/CCAPI/cc_api_voice_mode_event:
   Call Id=268
   Call Entry(Context=0x3258DA30)
Jul 12 10:46:25.647: //268/A9927CBC8285/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x34, Call Id1=268, Call Id2=269
Jul 12 10:46:36.695: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x10D
Jul 12 10:46:36.695: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
Jul 12 10:46:37.095: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:37.095: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
Jul 12 10:46:37.683: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 4 to dstCallId 0x10D
Jul 12 10:46:37.683: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:38.071: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:38.071: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:46:38.295: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x10D
Jul 12 10:46:38.295: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:38.543: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:38.543: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:46:38.655: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:46:38.655: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:38.723: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:38.723: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:46:50.943: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:46:50.943: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:51.183: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:51.183: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:46:51.215: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:46:51.215: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:51.283: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:51.283: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:46:51.515: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:46:51.515: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:52.075: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:52.075: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:46:52.111: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:46:52.111: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:52.183: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:52.183: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:46:52.615: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:46:52.615: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:46:52.915: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:46:52.915: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:47:09.575: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:47:09.575: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:47:09.975: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:47:09.975: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:47:10.527: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:47:10.527: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:47:10.935: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:47:10.935: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:47:11.351: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:47:11.351: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:47:12.171: //268/A9927CBC8285/CCAPI/cc_api_call_digit_end:
Jul 12 10:47:12.171: //268/A9927CBC8285/CCAPI/cc_relay_digit_end_for_3way_conference:
Jul 12 10:47:26.915: //268/A9927CBC8285/CCAPI/cc_api_call_digit_begin:
Jul 12 10:47:26.915: //268/A9927CBC8285/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jul 12 10:47:27.219: //268/A9927CBC8285/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=268
Jul 12 10:47:27.219: //269/A9927CBC8285/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x2B312EA8, Call Id=269
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jul 12 10:47:27.219: //268/A9927CBC8285/CCAPI/ccConferenceDestroy:
   Conference Id=0x34, Tag=0x0
Jul 12 10:47:27.219: //268/A9927CBC8285/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=269, Disposition=0x0, Tag=0x0
Jul 12 10:47:27.219: //269/A9927CBC8285/CCAPI/cc_api_bridge_drop_done:
Jul 12 10:47:27.219: //268/A9927CBC8285/CCAPI/cc_generic_bridge_done:
Jul 12 10:47:27.223: //268/A9927CBC8285/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 12 10:47:27.223: //268/A9927CBC8285/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 12 10:47:27.223: //269/A9927CBC8285/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jul 12 10:47:27.235: //269/A9927CBC8285/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B312EA8, Tag=0x0, Call Id=269,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 12 10:47:27.235: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 10:47:27.235: :cc_free_feature_vsa freeing 2AE9AA60
Jul 12 10:47:27.235:  vsacount in free is 1
Jul 12 10:47:27.255: //268/A9927CBC8285/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B73DD3C, Tag=0x0, Call Id=268,
Jul 12 10:47:27.255: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 10:47:27.255: :cc_free_feature_vsa freeing 2AE9A360
Jul 12 10:47:27.255:  vsacount in free is 0
My trunk and dial-peer configuration as below,
voice-port 0/3/1
trunk-group 02
no battery-reversal
no vad
cptone AE
connection plar opx 4445
caller-id enable
voice-port 0/3/2
trunk-group 02
no battery-reversal
no vad
cptone AE
caller-id enable
dial-peer voice 4445 voip
destination-pattern 4445
session protocol sipv2
session target ipv4:192.168.1.2
dtmf-relay sip-notify
dtmf-interworking rtp-nte
codec g711ulaw
no vad
If anyone has experienced this and got a resolution please share with me.
Kajen
3 REPLIES 3
Can you remove this command dtmf-interworking rtp-nte.  Once you have done that please test again and send the following debug for a call with dtmf failure
debug voip rtp session named-event
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
I have removed the "dtmf-interworking rtp-nte" and tried the debug command that you proposed.. But i don't see any output for the calls.
This analog line actually having couple of conversion in between and then only terminated to FXO port. Like,
Analog signal ----> IP signal -----> Analog signal (ISP is using multiple converters to bring the analog connection to CME)
And the connection is provided through WiMAX line then converted back to Analog.
I have noticed that when we press the extension number during the AA message, it says like calling and then says invalid number for unsuccessful calls ( Sometimes it says calling and then tells the extension number - Successful call).
Kajen
Can you please share how you resolved this issue.
Create
Recognize Your Peers
Content for Community-Ad
