08-26-2010 06:35 AM - edited 03-16-2019 12:29 AM
Weekend we migrated clients old PBX to CUCM 7.1.3-30000-1.
Setup has 2 nos of 2911 acting as MGCP gateway named as VG01 for BT and VG02 for COLT.
Gateway and the CUCM cluster are on the same LAN.
We are noticing that calls coming via VG02 (COLT) are getting disconnected intermittently after 4 seconds.
Debugs shows CUCM is not receiving Connect_ACK timer for the setup and after 4 seconds of the call, CUCM is adivsing the VG02 to drop the call.
We tried changing the T313 timer to 20K and noticed that calls disconnect after 20 seconds intermittently. ie., if 30 calls made 25 calls will be successful and 5 calls will fail.
Any thoughts regarding this issue is much apprecaited.
Thanks in advance.
Solved! Go to Solution.
08-26-2010 10:04 AM
Can you please grab the below data from the GW?
sho run
sho version
conf t
no logging console
no logging rate-limit
logging buffered 10000000 deb
service sequence
exit
debug isdn q931
debug mgcp packet
debug ccm-manager backhaul events
debug ccm-manager backhaul packet
Please send along the debugs and note the "calling" and "called" numbers for the failed call.
Thanks.
08-26-2010 10:04 AM
sho run
sho version
conf t
no logging console
service sequence
exit
debug isdn q931
debug mgcp packet
Thanks.
08-27-2010 09:37 AM
08-31-2010 11:21 AM
You'll want to open a TAC case for this.
A new defect was opened for this issue within the past week:
CSCti59648
Gateway delays back-hauling ISDN CONNECT_ACK to callmanager
All layer 3 isdn signaling is backhauled to call manager, so there shouldn't be any delay...but for some reason, in the case of 151-M1, you can see the message isn't being backhauled to CUCM, causing the T313 timer to fire.
-Dave
08-31-2010 01:57 PM
Hi Dave
thanks for the response. We opened the case last week itself. TAC engineer has opened a defect with DE
Eventually we changed the gateway from Mgcp to h323 and noticed still calls are getting dropped .
In H323 we noticed that **Error**L2_AdvanceVA:TX_queue_empty
Bug noticed this error corresponds CSCtf08864 which required special code to be released.
Like Sods law Mgcp/h323 gw issue haunted the customer.
Today evening we eventually changed the special ios for H323.
I will check with TAC Engineer to provide the fix for MGCP as per the bug mentioned.
Thanks for your help.
regards
12-20-2012 12:49 PM
Hello;
what was the result of the TAC case you opened?
12-20-2012 10:13 PM
New IOS on the voice gateway resolved the problem.
12-21-2012 11:03 AM
Just a question if you allow please, when you were facing the issue that the router wasnot backhauling the connect act message to CUCM; did you see the message on the debug isdn q931 "and not in CUCM trace" or you were not seeing it at all in either places?
