Intermittent ping to Cisco IP Phone
Sgj
When I test ping rep 100 from Core to Cisco IP Phone 3905, it's fine
CORE-01#ping 10.83.242.136 rep 100
Sending 100, 100-byte ICMP Echos to 10.83.242.136, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 1/1/8 ms
But when I test ping rep 100 from Core to IP Phone 6921, there's an intermittent
CORE-01#ping 10.83.237.131 rep 100
Sending 100, 100-byte ICMP Echos to 10.83.237.131, timeout is 2 seconds:
Success rate is 86 percent (86/100), round-trip min/avg/max = 1/1/4 ms
Any knows what happens with this? Maybe the config or anything else?
Thanks in advanced
Was awhile ago since I had anything to do with that awful line of phones, but if memory serves me yes that model would have this protection.
Response Signature
11 Replies 11
balaji.bandi
Can you post the port configuration along with any QoS  configured.
BB
Thanks for the reply,
This port was used for IP Phone 3905 :
interface GigabitEthernet1/0/18
 description CONNECT TO USER
 switchport access vlan 290
 switchport mode access
 switchport voice vlan 293
 mls qos trust device cisco-phone
 mls qos trust cos
 spanning-tree portfast
This port was used for IP Phone 6921 :
interface GigabitEthernet1/0/8
 mls qos trust cos
Can you tried ping from the PC?
cause may be phone itself not able to reply all of the icmp packets sent from the router.
Is there any configuration for this type of IP Phone 6921?
 do you face any issues with  calls ?
Response Signature
Yes, because the CDR shows cause code 41.
And now I'm still looking for the cause with valid data
This intermittent ping drop is expected.
you need to look in all components which involved in the voice communication.
Can you provide more information regarding your setup.
Response Signature
Sorry,
What kind of "setup" do you mean?
The configuration or what ?
This is expected. Some models of phones has a built in protection for ICMP, it will drop packages to offload the CPU.
Response Signature
Do you mean like IP Phone 6921 type?
Response Signature
