11-19-2012 02:16 PM - edited 03-16-2019 02:16 PM
I am having a weird issue where about 40% of EXTERNAL (internal work fine as per customer) calls get dropped when CUC tries to transfer them to a user, Hunt Pilot or External party. This happens both after hours and business hours, so i dont think its related to
Topology: SIP Integration everywhere with G711.(i will confirm the specific versions in a while)
ITSP---->CUBE G.711alaw----->SIP Trunk to CUCM---->CUCM----->2 SIP Trunks to individual CUCs on G.711ulaw---->CUC G.711alaw (plays prompt then transfers)---->back to CUCM to hunt pilot.
Error:
The CUBE shows error code 65(bearer capability mismatch) for failed calls.
Problem Description:(will attach the logs soon)
The Calls hit the CUC and system greeting/prompt is played "wait while we transfer the call" and then the call simply drops.
I opened a case TAC case with CUC team that got transferred to CUCM team who came back saying CUCM is getting this message to drop the call.
The reason they proposed was:
"when CUC tries to transfer CUCM gets a REFER from CUC which CUCM relays to CUBE as INVITE. for successful calls we get a OK response but for unsuccessful calls we get BYE"
I then worked with the CUBE team and was told that the service provider is changing the parateres for the re-invite which is why the calls are being droppped.
55 14:59:43.302 INVITE XXXXX6971 W/ SD->
206 14:59:43.310 INVITE 6971 W/ SDP----->
244 14:59:43.314 <-------------100 Trying
257 14:59:43.314 <-------------100 Trying
271 14:59:43.362 <------------180 Ringing
298 14:59:43.362 <------------180 Ringing
315 14:59:43.450 <---------200 OK W/ SDP
419 14:59:43.454 ACK 6971--------------->
437 14:59:43.454 <---------200 OK W/ SDP
470 14:59:43.466 ACK XXXXX6971---------->
483 14:59:45.714 <-INVITE 004161XXXXX W/
550 14:59:45.718 <-INVITE 4161XXXXX W/ SD
586 14:59:45.718 100 Trying------------->
600 14:59:45.770 200 OK W/ SDP--------->
648 14:59:45.774 <----------ACK 4161XXXXX
670 14:59:45.774 <----------BYE 4161XXXXX
687 14:59:45.774 BYE 004161XXXXX-------->
704 14:59:45.778 200 OK----------------->
727 14:59:45.782 <-----------------200 OK
in above call, first INVITE from Telco has codec 8 0 18 96; when Telco responds the RE-INVITE (codec 8 96 19) from CUBE, it has codec 97 96, which causes CUBE not able to find common codec."
I escalated this with the service provider who is reluctant to accept that anything is wrong on their end.
What I do not understand is why is:
1) why does this happen only for call transfer from CUC
2) why only a few EXTERNAL calls.
I understand that at this stage I have not provided the logs and versions for the servers, but any insight on this issue will be greatly appreciated.
11-19-2012 03:38 PM
How many CUCM servers do you have in the cluster? Is your SIP trunk for UCXN configured with "route on all nodes"? How are the port groups configured in UCXN, i.e. which CUCM servers are they pointing to?
Are both UCXN SIP trunks configured with the same CSS?
Chris
11-19-2012 08:14 PM
Thank you Chris for the prompt reply.
The issue was at the service provider end as they implemented new Gateway that didn't sent G.711 during reinvite. They have rolled back their change and calls are working as normal.
TAC was right the whole time.
