Internal call only and certain external numbers
linda
Beginner
Beginner
I have a requirement where a Cisco 7911 phone extension should only be able to call internal extensions and some external numbers. (mobile numbers)
I have tried several methods including creating an extension and setting the call-forward all to the external number but still when i call it the internal cor list prevents the call.
Does anyone know how to achieve this?
Many thanks
6 Replies 6
acampbell
Advocate
Advocate
Linda,
Can you provide your existing config,
Extension number with feature required
The full external number(s) to be allowed.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi Alex,
Thanks for your reply. I sat and thought about this problem a bit more, i thought about creating outbound call rules using the full mobile number and set the rule to emergency and this worked. So this extension can call internal extensions and 3 mobile numbers.
Best Regards
Linda,
Here is a link re COR
This may help you.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Alex.
Hi All,
I have the same kind of requirement but in Cisco UCM environment. Configure 7911 phone that can call internal and few external numbers only. I would appreciate if someone guide me or provide me docs how to proceed to configure.
Thanks in advance
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
All that is controlled via CSS and partitions, you just need to configure as required for your environment.
java
if this helps, please rate
You can go through the below link:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/22325-part-css-tn.html
Aseem
(Please rate if useful)
Recognize Your Peers
