08-03-2012 07:52 AM - edited 03-16-2019 12:31 PM
I have a requirement where a Cisco 7911 phone extension should only be able to call internal extensions and some external numbers. (mobile numbers)
I have tried several methods including creating an extension and setting the call-forward all to the external number but still when i call it the internal cor list prevents the call.
Does anyone know how to achieve this?
Many thanks
08-03-2012 08:56 AM
Linda,
Can you provide your existing config,
Extension number with feature required
The full external number(s) to be allowed.
Alex.
Please rate useful posts.
08-06-2012 11:38 PM
Hi Alex,
Thanks for your reply. I sat and thought about this problem a bit more, i thought about creating outbound call rules using the full mobile number and set the rule to emergency and this worked. So this extension can call internal extensions and 3 mobile numbers.
Best Regards
08-07-2012 01:31 AM
Linda,
Here is a link re COR
This may help you.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Alex.
09-28-2016 07:20 AM
Hi All,
I have the same kind of requirement but in Cisco UCM environment. Configure 7911 phone that can call internal and few external numbers only. I would appreciate if someone guide me or provide me docs how to proceed to configure.
Thanks in advance
09-28-2016 07:38 AM
All that is controlled via CSS and partitions, you just need to configure as required for your environment.
09-28-2016 08:55 AM
You can go through the below link:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/22325-part-css-tn.html
Aseem
(Please rate if useful)
