04-01-2013 09:11 AM - edited 03-16-2019 04:32 PM
When Mobility users call another internal extension from their mobile phones, the caller ID is supposed to show the calling party's internal extension and not the mobile number. CUCM is no longer associating remote destinations with internal extensions in regards to Caller ID all of a sudden. I have not made any changes so not sure what happened.
Any ideas or what to look for? Thanks!
Solved! Go to Solution.
04-04-2013 05:40 PM
Check the following CM Service Parameters:
Matching Caller ID with Remote Destination Required Field = Set to partial match
Number of Digits for Caller ID Partial Match Required Field = Set to 9 digits
Heath
04-02-2013 02:48 AM
Hi Aaron.
Please check if the CUCM is receiving mobile number as you configured in remote destination.
Check also if you are doing any digit manipulation of calling party number on CUCM or VG.
Carlo
04-02-2013 10:49 AM
Thanks Carlo.
CUCM receives the number as 10 digits. The remote destinations are configured as 10 digits with the 9 prepended for PSTN access. No digit manupulation for incoming external calls.
It's been working for years and all of sudden quit. It may have stopped working after an upgrade to 8.0 to 8.6 but I'm just speculating. It's been about 4 months since I performed the upgrade and am just noticing it.
04-02-2013 11:44 AM
Hi Aaron.
It usually happens when remote destination dosn't match the caller id.
If you prepend 9 to call back missed or received calls, remote destination should be configured as 9 plus external number.
Try also to deassociate and associate again the extension to remote destination.
Carlo
04-04-2013 08:52 AM
Carlo,
Something must have changed from 8.0 to 8.6. I removed the 9 in the Remote Destination numbers and the CID is now working as it should by showing internal extension rather than mobile number.
Back when this system was deployed on 7.X, the 9 had to be there for Mobile Connect to even make the call outbound to the RD. Now the it works without the 9 and I'm not sure how it knows 9 for PSTN access without prepending it to the number.
Aaron
04-04-2013 09:15 AM
Hi Aaron.
Glad to know that it works now.
We have some customers using SNR with cucm 8.6.
We always prepend 0 (the access code used here in Italy) to the incomnig calling number and remote destinations are configured with 0 before the external number.
Do you prepend 9 at which level (VG, CUCM translation)?
Carlo
Please rete helpful posts
04-04-2013 10:37 AM
Carlo,
We're only prepending with Application Dial Rules for things like Jabber, CUPC, etc. No translation patterns or GW level prepend. That is why I questioned how SNR is making the outbound calls without the 9 configured before the 10 digit RD number.
Aaron
04-04-2013 05:40 PM
Heath
