04-25-2019 05:40 PM
Do we have any configuration in Cisco, which allows the internal calls between two IP phones to be routed via Cisco voice gateways. In Avaya we have the feature called Hair pinning and if it disabled, the internal calls between IP phones are routed via gateways.
Karthi Devaraj
04-25-2019 07:25 PM
in what scenario? CUCM? in which case the answer is no.
can you explain what your setup is and what problem you are trying to resolve
thanks
04-25-2019 07:34 PM
We are trying to configure voice recording by mirroring the voice gateway ports. This will only provide the incoming and outgoing calls. Hence want to explore, if there is any option to bring the RTP flow leveraging the gateway for internal calls, so the recording can be performed for all scenarios.
Customer doesnt want to do BIB or NBR based option, as parallel recording wont be possible and they cant upgrade to CUCM 12.5 to achieve the Multi Forking capability, as upgrade is not under plans as of now.
Karthi
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
