internal calls going to voice mail problem and forwarding problem.
khenning
Hello All,
first off it is
Cisco Unity Connection version: 9.1.1ES23.21019-23
We have multiple buildings in our system and I am having problems at one of the buildings.
When I call any of the extensions in the building from another extension in the building. the phone will ring until not answered and voice mail does kick in. I leave a message and hang up.
The phone never shows it has a message. When I go into unity connections and look, it also shows no message was left.  If I call from a different building to this building and leave a message it does show up.
The other problem in this same building is that when they do have a message and want to forward it to another extension, they go through the complete process and when they press the pound key to forward the message. the system says that it cannot complete the call at this time and hangs up.
All help is appreciated.
Kevin
Rob Huffman
Hi Kevin,
To me, it sounds like a CSS/Partition issue. Have a close look
at those settings for the phones in the "trouble" building
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
OK, Here is what I found with this problem and it fixes the issues at hand.  Right now, because of the way we do our programming we do not have a display name under the field User basic screen. Once we enter even just a letter the problem goes away.  We never had to have a display name entered before. thsi problem started after we did an upgrade to the current version.  Does anyone know if this is a bug or a fix for something else?
Kevin
Hello Kevin,
I see time has gone by with this thread but i would just like to add additional input in case anyone else runs into this problem.
Applicable bug for this is: CSCtr35533 CUC Message delivery fails when Display Name contains special character
Fix should be ready in CUC 10.x
From the CUC tracing perspective you would see the following output on the Conversation Manager traces, in the example below you can see that s="" is where the displayed name should be and in this case is empty:
16:02:34.566 |8434,Call Manager-010,ED6FB6696E3D46EEBE0E5AA91951147A,CML,13,E_INVALIDARG (0x80070057) Unable to set header CallerName on outbound draft message draftmsg:(s="" a=33000 l=ENUENU type=NEW)[ [pos=1  ct="" cst=           cfn=           ccs=           ce=]] from "" .  Logged from HRESULT CCsCmlUmssDraftMessage::SetHeadersOnDH(CCsMalDeliveryHelper&) in CsCml/CsCmlUmssDraftMessage.cpp at line 585.
16:02:34.567 |8434,Call Manager-010,ED6FB6696E3D46EEBE0E5AA91951147A,CML,13,E_INVALIDARG (0x80070057) Unable to send draftmsg:(s="" a=33000 l=ENUENU type=NEW)[ [pos=1  ct="" cst=           cfn=           ccs=           ce=]] from "" .  Logged from static void* CCsCmlUmssDraftMessage::SendThreadProc(void*) in CsCml/CsCmlUmssDraftMessage.cpp at line 340.
16:02:34.568 |8434,Call Manager-010,ED6FB6696E3D46EEBE0E5AA91951147A,-1,-1,An error has occurred while attempting to assemble and send a new message from "" to "Pleidian" . Message could not be sent, see log file for more information.
16:02:34.568 |8434,Call Manager-010,ED6FB6696E3D46EEBE0E5AA91951147A,CDE,-1, : CCsSMsgSend::OnEntry : CCsCmlDraftMessage::Send() failed, hr=0x80070057 E_INVALIDARG [Src/CsSMsgSend.cpp:253]
-Regards
|]A|/I|]
