Internal Calls Has No Sound
Kan Aky
Beginner
Beginner
We are using IPSEC VPN between different buildings, but using same CM. Some of internal calls are silence (headphone/speaker)(internal code like 2020) dialing with external code sounds clear. What may cause to silence calls for some internal lines? This problem is two way problem.
Also:
Building A: Using VLAN 20 for lines
Building B: Using VLAN 104 for lines
Few weeks later i realized some of the lines (@Building A) using VLAN 22 ip length.(Cuz of FW rules) After i updated those lines VLAN to 20. After update calls were clear. Now i update other lines to VLAN 20, but those lines still silence when dialing with internal code.
5 Replies 5
George Sotiropoulos
Hello Kan,
Very quickly you need to verify the routing between the 2 ends and your CUCM. You need to make sure that the 2 IP phones are able to "reach" each other by ping and that both of them are able to ping your CUCM.
Can you check this and get back to us?
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Thanks for respond, sorry for late back. I had some ping tests. Building A lines can be pinged from CM, Building B lines are unable ping from CM.
