Internal calls on jabber and external calls on landline phone
RFC_2549
Beginner
Beginner
Hello!
If I have on CUCM a directory number (example 100) associated with a Cisco landline phone and a Jabber, can I only receive calls from outside on the Cisco landline phone and receive the calls from inside only on the Jabber?
Thank You!!!
Ritesh Desai
Contributor
Contributor
Yes, you can. Assign 2 different Partitions. Landline-PT and JABBER-PT. assign to Phones accordingly. On 2 Incoming trunk you can assign Incoming Calls CSS as Landline and Jabber.
Keep the directory number 100 as you said.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
