05-30-2007 07:14 AM - edited 03-14-2019 09:47 PM
it seems that every now and then faxes sent to other internal faxes do not go through. both ATA can ping each other and can see no loss of connectivity. Where do I start troubleshooting this?
05-30-2007 07:54 AM
wot do u mean "dont go through".
R u getting half page output OR
not able to reach destination OR
not receiving at all
06-20-2007 07:58 AM
I am actually having a similar problem. I can hear the handshake and then the fax dies. I get nothing on the other side. Sometimes it will be blank pages. Any thoughts?
06-20-2007 08:13 AM
pls note ATA is not a good solution for fax. try to use FXS or VG248. it would be better.
06-20-2007 08:14 AM
Sorry I am using FXS.
