05-15-2017 06:28 AM - edited 03-17-2019 10:19 AM
Dear all
we have an issue with international call on cme
we have one dial peer matched national and international calls
national calls success
international calls failed and below the output of debug isdn
Please we need your help
041030: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 148
041031: ISDN Se0/2/0:23 Q931: Sending SETUP callref = 0x01CA callID = 0x80F1 switch = primary-ni interface = User
041032: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8 callref = 0x01CA
Sending Complete
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '148'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x91, '0119XXXXXXXXX8'
Plan:ISDN, Type:International
041033: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x81CA
041034: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x81CA
Progress Ind i = 0x8188 - In-band info or appropriate now available
041035: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x81CA
Cause i = 0x8290 - Normal call clearing
041036: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x01CA
041037: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81CA
Solved! Go to Solution.
05-15-2017 07:18 AM
You are getting DISCONNECT from the carrier, can you try sending the call out with real caller ID instead of '148'? If that does not work you can try adjusting called plan and isdn type to "Unknown", "Unknown" and try that, if that does not work I would reach out to your telco provider and find out why the reject the call.
05-15-2017 08:48 AM
Hi Remon,
Like Chris said earlier we are still receiving disconnect from service provider.
002124: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x813D
http://www.cisco.com/c/en/us/support/docs/dial-access/integrated-services-digital-networks-isdn-channel-associated-signaling-cas/8607-isdn-disc-code.html#topic1
82 | No route to specified network | The ISDN exchange receives a request to route the call through an unrecognized intermediate network. This cause indicates that the equipment receives a request to route the call through a particular transit network. However, the equipment does not recognize the network. The equipment that sends this cause does not recognize the transit network due to one of these reasons:
You would need to contact telco and they would tell you what do they dont like with you ISDN setup message.
(Rate if it helps)
JB
05-15-2017 09:05 AM
As stated in my initial reply, you will need to contact your provider and have them look on their side. It could be something as simple as international calls not being permitted on this PRI.
05-15-2017 07:18 AM
05-15-2017 08:27 AM
Dear Chris
I tried the above suggestion bu failed and below the debug output of two cases :-
001990: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 3472854151
001991: ISDN Se0/2/0:23 Q931: Sending SETUP callref = 0x012F callID = 0x80B0 switch = primary-ni interface = User
001992: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8 callref = 0x012F
Sending Complete
Standard = CCITT
Calling Party Number i = 0x2180, '3XXXXXXXX1'
Plan:ISDN, Type:National
Called Party Number i = 0x91, '011XXXXXXXXXXX8'
001993: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x812F
001994: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x812F
001995: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x812F
001996: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x012F
001997: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x812F
_________________________________________________________________________________________________
UC520(cfg-translation-rule)#
002119: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 148
002120: ISDN Se0/2/0:23 Q931: Sending SETUP callref = 0x013D callID = 0x80BE switch = primary-ni interface = User
002121: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8 callref = 0x013D
Sending Complete
Standard = CCITT
Called Party Number i = 0x80, '011XXXXXXXXXXX8'
002122: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x813D
002123: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x813D
002125: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x013D
002126: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x813D
05-15-2017 08:48 AM
Hi Remon,
(Rate if it helps)
JB
05-15-2017 09:05 AM
