04-11-2015 03:11 AM - edited 03-17-2019 02:37 AM
Dears,
i have a CME 10.5 with 4-FXO ports and SIP phones i want to restrict all international calls with a 'PIN' .. so only people knows that PIN will be able to dial Int-calls
note: all calls routed thru the 4-FXO ports
thanks
04-11-2015 10:31 AM
Hi Amer,
Please try to go through the entire content on below mentioned link.
https://supportforums.cisco.com/discussion/11147326/how-get-lpcor-working-cme-85
Raaj.
04-11-2015 03:56 PM
you can apply the COR_LIST that you will achieve you requirement. Users you have access to International only they would be able to dial out International call rest will not.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
Br,
Nadeem
