1722
KBCISCO
Beginner
International Dialing - New Zealand
Hi, I am having some issues with a new CME that I have configured in New Zealand. I can make local calls but can not call out International. I have checked with the telco and the ISDN Pri is not restricted.
I'm assuming I have made a mess up with the translation rules but I'm not a voice guy and not sure where to begin with troubleshooting this.
I have pasted a chunk of the configuration below (real DDI has been changed). Any help would be much appreciated.
K
isdn switch-type primary-net5
trunk group FXO
hunt-scheme sequential both up
voice call disc-pi-off
voice class codec 10
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice translation-rule 1
rule 1 // /00/ type national national
rule 2 // /000/ type international international
voice translation-rule 2
rule 1 /^0\.*/ /\1/
voice translation-rule 3
rule 1 /^\.*/ /09312\1/
voice translation-rule 4
rule 1 /^312/ //
voice translation-profile PSTN-Incoming
translate calling 1
translate called 4
voice translation-profile PSTN-Outgoing
translate calling 3
translate called 2
voice-card 0
dsp services dspfarm
controller E1 0/1/0
pri-group timeslots 1-10,16
interface FastEthernet0/0.52
description ** MGMT VLAN Interface **
encapsulation dot1Q 52
ip address 10.8.173.12 255.255.255.128
interface FastEthernet0/0.53
description ** Voice VLAN Interface **
encapsulation dot1Q 53
ip address 10.8.173.130 255.255.255.128
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Internal-Service-Module0/0
ip unnumbered FastEthernet0/0.52
service-module ip address 10.8.173.13 255.255.255.128
!Application: CUE Running on AIM2
service-module ip default-gateway 10.8.173.12
hold-queue 512 out
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0:15
translation-profile incoming PSTN-Incoming
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
sccp local FastEthernet0/0.53
sccp ccm 10.8.173.130 identifier 1 version 6.0
sccp
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
associate application SCCP
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
forward-digits all
dial-peer voice 10 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind connect enable 8
port 0/1/0:15
forward-digits all
dial-peer voice 3 pots
translation-profile outgoing PSTN-Outgoing
destination-pattern 0[2-9].......
port 0/1/0:15
forward-digits all
dial-peer voice 4 pots
destination-pattern 01[1-2]T
port 0/1/0:15
forward-digits all
dial-peer voice 5 pots
destination-pattern 013T
port 0/1/0:15
forward-digits all
dial-peer voice 6 pots
destination-pattern 00[1-9]........
port 0/1/0:15
forward-digits all
dial-peer voice 7 pots
destination-pattern 0016......
port 0/1/0:15
forward-digits all
dial-peer voice 8 pots
destination-pattern 0001[0-9]T
port 0/1/0:15
forward-digits all
dial-peer voice 9 pots
destination-pattern 0009T
port 0/1/0:15
forward-digits all
dial-peer voice 12 pots
destination-pattern 01900......
port 0/1/0:15
forward-digits all
dial-peer voice 11 pots
destination-pattern 00055......
port 0/1/0:15
forward-digits all
dial-peer voice 15 pots
destination-pattern 01800......
port 0/1/0:15
forward-digits all
dial-peer voice 16 pots
destination-pattern 0000
port 0/1/0:15
forward-digits all
dial-peer voice 2000 voip
description ** CUE VOICEMAIL **
destination-pattern 9388
session protocol sipv2
session target ipv4:10.8.173.13
dtmf-relay sip-notify
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:10.8.173.13 expires 3600 port 5060 transport udp
telephony-service
sdspfarm units 2
max-ephones 30
max-dn 150
ip source-address 10.8.173.130 port 2000
auto assign 1 to 5
url services http://10.8.173.13/voiceview/common/login.do
time-zone 48
time-format 24
date-format dd-mm-yy
voicemail 9388
max-conferences 3 gain -6
moh music-on-hold.au
multicast moh 239.1.100.1 port 2000
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  16  dual-line
number 9316
description +64 9 312 9316
name Test phone 1
call-forward busy 9388
call-forward noan 9388 timeout 15
mwi sip
ephone  1
mac-address 5478.1AE0.4387
type 7942
button  1:16
10 REPLIES 10
Bruno Rangel
Advocate
When you make a International call what exactly are you dialing ? all digits included the access code zero.
You can find the error with
Debug isdn q931
debug voice ccapi inout
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Hi Bruno,
When calling Australia, the guys on site are dialing 0 for an outside line, followed by 00 - 61 - Area Code - TEL # (i.e
00061299511888)
I have pasted the output below from the debugs
Called Number=00061299511888(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=10, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Nov 15 04:17:15.087: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 15 04:17:15.087: :cc_get_feature_vsa malloc success
*Nov 15 04:17:15.087:  cc_get_feature_vsa count is 2
*Nov 15 04:17:15.087: :FEATURE_VSA attributes are: feature_name:0,feature_time:1742120072,feature_id:12
*Nov 15 04:17:15.087: //12/29C57FB68029/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Nov 15 04:17:15.091: //12/29C57FB68029/CCAPI/ccCallSetContext:
   Context=0x67D82854
*Nov 15 04:17:15.091: //11/29C57FB68029/CCAPI/ccSaveDialpeerTag:
*Nov 15 04:17:15.099: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 9316
*Nov 15 04:17:15.099: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0083 callID = 0x8004 switch = primary-net5 interface = User
*Nov 15 04:17:15.103: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0083
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0180, '9316'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '00061299511888'
*Nov 15 04:17:15.203: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8083
*Nov 15 04:17:22.711: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8083
*Nov 15 04:17:22.715: //12/29C57FB68029/CCAPI/cc_api_call_proceeding:
   Interface=0x6748F66C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3
Call goes out with the orignal calling number and that may not be acceptable by telco.
Try use the translation rule like that to change your calling number:
voice translation-profile PSTN-Outgoing-ITNL
translate calling 3
Add that to dial-peer voice 10 pots
If still trouble, look at complete debug isdn q931, and nothing else.
Cheers
Bruno Rangel
Cheers
Bruno Rangel
I seem to be getting somewhere with this. I can dial internationally from the CLI line when I type the following command csim start 0061299512121
but I still can't dial internationally from a handset. Must be something with my translation rules?
Try change your dial-peer voice 10 with no forward-digits all
Please rate all post using the stars
Cheers
Bruno Rangel
Renato Russo
Cheers
Bruno Rangel
Hi, I tried that but still unable to dial international from the handset. Can only dial from the command line
When you dial it from the command line you dialed 0061299512121, but from the phone you dialed 00061299512121, ie with a zero in front for the outside prefix. In your original debug it showed that you didn't remove the outside prefix from the called number, you need to setup your outgoing voice translation rule to remove that extra zero or use dial peer digit drop to remove it.
On all other outgoing pots dial peers you have a outgoing voice translation, but not on the one used for international calls, DP 10. Why is that?
Add the translation to that dial peer with the below commands.
That will both take care of called number, ie drop the leading zero and also set the calling number to the format that your Telco seem to want it in.
Please remember to rate all useful posts.
Response Signature
Thanks for everyones help on this but after trying all suggestions,  i am still have a issues dialing international. I am going to ring the Telco after the weekend and see if they can see any issues at their end.
Below is my latest debug when calling an international number 0006199501234 (I have change dlast 6 digits of real number)
As you can see, the first 0 is dropped but the call still doesnt get through.
If I type 'csim start 006199501234' from the command line the call goes through
                Standard = CCITT
        Channel ID i = 0xA98389
                Exclusive, Channel 9
        Calling Party Number i = 0x1183, '0931200061400945432'
                Plan:ISDN, Type:International
        Called Party Number i = 0x81, '0061499501234'
*Nov 24 08:05:02.361: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8124
*Nov 24 08:05:02.561: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8125
*Nov 24 08:05:03.001: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8125
        Cause i = 0x87FF - Interworking error; unspecified
*Nov 24 08:05:03.005: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0125
*Nov 24 08:05:03.017: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x91E1
        Cause i = 0x80FF - Interworking error; unspecified
*Nov 24 08:05:03.033: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8125
*Nov 24 08:05:03.105: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x11E1
*Nov 24 08:05:03.105: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x91E1
The first thing that pops to mind is that you have totally different calling numbers in your two posts.
Below part is from your latest post.
And this is from your previous post.
So you must have changed more than what was suggested by me and Bruno between the two posts. Please describe the changes made for us to be able to help.
Also you say that it works when you do a csim start, could you please post the output from these debugs when you do a csim.
debug isdn q931
debug voip dialpeer
debug voice translation
Post them as separate output.
The thing that still stands out to me is that you do the successful csim start call with a called number that is different than what you use on the phone. Why is that? Do you have a DDI in the CUCM that drops the prefix 0 (zero) before its sent to the VGW? If not, ie you send the complete called number from CUCM to the VGW and do all digits manipulation in it, you should use the same format for called number when you do the csim start. Otherwise the test won't reveal the reason for why you have problem with calling to a international number.
Response Signature
International calls started working after speaking to the Telco. Cheers for all the advice guys
Create
Recognize Your Peers
Content for Community-Ad
