International Dialing
mightyking
Level 6
Level 6
I don't know what happend since this afternoon our international calls are not going out. Here's the output of debug ccapi:
Nov 13 01:15:03.439 EST: //-1/0013D7580302/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Darlene Dwyer
   ----- ccCallInfo IE subfields -----
   cisco-ani=55557
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=90113491310711
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov 13 01:15:03.439 EST: //-1/0013D7580302/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x70A5CE0C, Call Info(
   Calling Number=55557,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90113491310711(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10220011, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2003
Nov 13 01:15:03.439 EST: //-1/0013D7580302/CCAPI/ccCheckClipClir:
   In: Calling Number=55557(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=55557(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Nov 13 01:15:03.439 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 13 01:15:03.439 EST: :cc_get_feature_vsa malloc success
Nov 13 01:15:03.439 EST:  cc_get_feature_vsa count is 1
Nov 13 01:15:03.439 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1971458984,feature_id:2003
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=55557(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90113491310711(TON=Unknown, NPI=Unknown))
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/cc_process_call_setup_ind:
   Event=0x70F9CEF8
Nov 13 01:15:03.439 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 90113491310711
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/ccCallSetContext:
   Context=0x756F12B8
   >>>>CCAPI handed cid 2003 with tag 10220011 to app "_ManagedAppProcess_Default"
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/ccCallProceeding:
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1050, Params=0x756F21F8, Progress Indication=NULL(0)
Nov 13 01:15:03.439 EST: //2003/0013D7580302/CCAPI/cc_fill_tg_params:
   Not a cic call
   Trunk Group Select Interface Success;
   Interface=0x692FE574, Selected Interface=1, Selected DSL=1
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccCheckClipClir:
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccCallSetupRequest:
   Destination Pattern=9011T, Called Number=90113491310711, Digit Strip=TRUE
   Redirect Number=, Display Info=Darlene Dwyer
   Account Number=Darlene Dwyer, Final Destination Flag=TRUE,
   Guid=0013D758-E72C-E1CD-0302-4A020A14293A, Outgoing Dial-peer=1050
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=55557
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=90113491310711
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x692FE574, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=55557,(Calling Name=Darlene Dwyer)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90113491310711(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1050, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=PRILD, tg_label_flag=2, Application Call Id=)
Nov 13 01:15:03.443 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 13 01:15:03.443 EST: :cc_get_feature_vsa malloc success
Nov 13 01:15:03.443 EST:  cc_get_feature_vsa count is 2
Nov 13 01:15:03.443 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1971458760,feature_id:2004
Nov 13 01:15:03.443 EST: //2004/0013D7580302/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
rtprtr03#
Nov 13 01:15:03.443 EST: //2004/0013D7580302/CCAPI/ccCallSetContext:
   Context=0x756F21A8
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/ccSaveDialpeerTag:
Nov 13 01:15:03.443 EST: //2003/0013D7580302/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=PRILD, tg_label_flag=TRUE, Call Id=0x7D3
Nov 13 01:15:03.523 EST: //2004/0013D7580302/CCAPI/cc_api_call_proceeding:
   Interface=0x692FE574, Progress Indication=NULL(0)
rtprtr03#
Nov 13 01:15:04.899 EST: //2004/0013D7580302/CCAPI/cc_api_call_cut_progress:
   Interface=0x692FE574, Progress Indication=NOT END TO END ISDN(1), Signal Indication=INTERCEPT(2),
   Cause Value=28
   Call Entry(Responsed=TRUE)
Nov 13 01:15:04.899 EST: //2003/0013D7580302/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=28
   Voice Call Send Alert=TRUE, Call Entry(Alert Sent=FALSE)
   Call CallAlert;
Nov 13 01:15:04.899 EST: //2003/0013D7580302/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Nov 13 01:15:04.899 EST: //2004/0013D7580302/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Nov 13 01:15:04.903 EST: //2003/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x751ED254, callID1=0x7D3, callID2=0x7D4, tag=0x0)
   (confID=0x751ED254, callID1=0x7D3, gcid=0-0-0-0, tag=0x0)
Nov 13 01:15:04.903 EST: //2004/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x751ED254, callID2=0x7D4, gcid=0-0-0-0, tag=0x0)
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/ccConferenceCreate:
   Conference Id=0x751ED254, Call Id1=2003, Call Id2=2004, Tag=0x0
Nov 13 01:15:04.903 EST: //2003/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Nov 13 01:15:04.903 EST: cc_api_get_xcode_stream : 4510
Nov 13 01:15:04.903 EST: //2003/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x26F, Source Interface=0x70A5CE0C, Source Call Id=2003,
   Destination Call Id=2004, Disposition=0x0, Tag=0x0
Nov 13 01:15:04.903 EST: //2004/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x26F, Source Interface=0x692FE574, Source Call Id=2004,
   Destination Call Id=2003, Disposition=0x0, Tag=0xFFFFFFFF
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x26F, Destination Call Id=2004)
Nov 13 01:15:04.903 EST: //2004/0013D7580302/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x26F, Destination Call Id=2003)
Nov 13 01:15:04.903 EST: //2004/0013D7580302/CCAPI/cc_api_caps_ind:
   Destination Interface=0x70A5CE0C, Destination Call Id=2003, Source Call Id=2004,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x26F, Call Id1=2003, Call Id2=2004
Nov 13 01:15:04.903 EST: //2003/0013D7580302/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=2003
Nov 13 01:15:04.903 EST: //2004/0013D7580302/CCAPI/cc_api_get_called_ccm_detected:
Nov 13 01:15:04.919 EST: //2003/0013D7580302/CCAPI/cc_api_caps_ind:
   Destination Interface=0x692FE574, Destination Call Id=2004, Source Call Id=2003,
   Caps(Codec=0x1, Fax Rate=0x80, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Nov 13 01:15:04.919 EST: //2003/0013D7580302/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_14400(0x80), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5587)
Nov 13 01:15:04.919 EST: //2004/0013D7580302/CCAPI/cc_api_caps_ack:
Nov 13 01:15:04.919 EST: //2004/0013D7580302/CCAPI/cc_api_voice_mode_event:
   Call Id=2004
rtprtr03#
   Call Entry(Context=0x756F21A8)
rtprtr03#
Nov 13 01:15:07.663 EST: //2003/0013D7580302/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x70A5CE0C, Call Id=2003
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Nov 13 01:15:07.663 EST: //2003/0013D7580302/CCAPI/ccConferenceDestroy:
   Conference Id=0x26F, Tag=0x0
Nov 13 01:15:07.663 EST: //2003/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Nov 13 01:15:07.663 EST: //2004/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2003, Disposition=0x0, Tag=0x0
Nov 13 01:15:07.663 EST: //2003/0013D7580302/CCAPI/cc_generic_bridge_done:
Nov 13 01:15:07.663 EST: //2004/0013D7580302/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
rtprtr03#
Nov 13 01:15:07.663 EST: //2004/0013D7580302/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Nov 13 01:15:07.667 EST: //2003/0013D7580302/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Nov 13 01:15:07.667 EST: //2003/0013D7580302/CCAPI/cc_api_get_transfer_info:
Nov 13 01:15:07.715 EST: //2004/0013D7580302/CCAPI/cc_api_call_disconnect_done:
rtprtr03#
rtprtr03#Disposition=0, Interface=0x692FE574, Tag=0x0, Call Id=2004,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   tg for this call is PRILD success/fail is 1
   Call Disconnect Event Sent
Nov 13 01:15:07.715 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 13 01:15:07.715 EST: :cc_free_feature_vsa freeing 758212C0
Nov 13 01:15:07.715 EST:  vsacount in free is 1
rtprtr03#
Nov 13 01:15:10.667 EST: //2003/0013D7580302/CCAPI/cc_api_get_transfer_info:
Nov 13 01:15:10.667 EST: //2003/0013D7580302/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x70A5CE0C, Tag=0x0, Call Id=2003,
Nov 13 01:15:10.667 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 13 01:15:10.667 EST: :cc_free_feature_vsa freeing 758213A0
and here's the config of the dial it is hitting:
dial-peer voice 1050 pots
trunkgroup PRILD
description International Outbound LD Circuit
destination-pattern 9011T
progress_ind progress enable 8
progress_ind connect enable 8
prefix 011
James Hawkins
Level 8
Level 8
The trace shows the call is being disconnected normally (cause 16)
Is there any chance you can post the output of debug isdn q931?
Also do calls to non-international destinations work? - if yes can you post debugs and the relevent dial-peer config
The message is "Your international call can not be completed as is dialed. The non internatinal calls work.  Here's the output of debut isdn q931.
Nov 13 09:21:58.865 EST: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0201
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Display i = 'GUEST PHONE - 31008'
        Calling Party Number i = 0x0181, '9199931008'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '011982122256563'
Nov 13 09:21:58.957 EST: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8201
rtprtr03#
Nov 13 09:22:10.397 EST: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0201
        Cause i = 0x8090 - Normal call clearing
Nov 13 09:22:10.425 EST: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8201
Nov 13 09:22:10.425 EST: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0201
rtprtr03#
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x1, Calling num 9199931008
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x0202 callID = 0x8215 switch = primary-ni interface = User
rtprtr03#
Nov 13 09:22:24.237 EST: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0202
                Standard = CCITT
        Called Party Number i = 0x81, '01198212225536'
Nov 13 09:22:24.309 EST: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8202
rtprtr03#
Nov 13 09:22:25.201 EST: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8202
        Cause i = 0x8781 - Unallocated/unassigned number
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
rtprtr03#
Nov 13 09:22:33.213 EST: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0202
Nov 13 09:22:33.253 EST: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8202
Nov 13 09:22:33.257 EST: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0202
It appears the provider suddenly wants you to set the ISDN numbering plan and type. Try adding this and then typing translation-profile outgoing PSTN_Trunk_Outgoing on your dial-peer:
voice translation-rule 1
rule 1 /^9011.*/ /\0/ type any international plan any isdn
rule 2 /^9[2-9]..[2-9]......$/ /\0/ type any subscriber plan any isdn
rule 3 /^9[2-9]......$/ /\0/ type any subscriber plan any isdn
rule 4 /^91[2-9]..[2-9]......$/ /\0/ type any national plan any isdn
voice translation-profile PSTN_Trunk_Outgoing
translate called 1
If this still doesn't fix it, it is also possible the provider does not want to see the 011 prefix when the TON value is set; try adjusting your dial-peer to remove that. If none of this fixes it, call your provider. Heck call them anyways and complain they changed the circuit configuration.
Thanks Jonathan, it worked :-)
