Internet Explorer 11 Bricks UCM Webpage
Brett Williston
My computer installed IE 11 last night and when I went to access the UCM webpage I couldn't access any of the drop down menus.
Does anyone know of a work around other than uninstalling IE 11?
geyerjh1
Level 4
Level 4
Uninstall the IE 11 update. IE 11 doesn't play well with others.
We have the same issue where CUCM Admin does not work with Windows 11. We are running Windows 8 and comes with IE 11 and you can't revert back to a previous version. So the response from geyerjh1 will not work.
Is Cisco going to fix CUCM so that it works with IE11?
Ran into the same problem after upgrading to IE11.  UCM, Unity, and UCCX all work fine under IE11 when they are added to the "Compatibility Vew" list in IE -- Tools > Compatibility View settings.
