Interplatform dialling - QSIG between CUCM and Netrix
Hi All
Our customer has QSIG integration between between CUCM and Netrix.
Experiencing some issue with call routing from Netrix phone to Extn number in CUCM ,...
call from CUCM to Netrix via Qsig is working fine.
does any know where could be the prolem that i need to look at.
Kind Regards
Jaime Valencia
I'd check the inbound CSS in CUCM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Java
Thanks for your response.
Call made form CUCM to Netrix worked ok but then the same tranfered back to CUCM via QSIG is not working
debug ISDN Q931 doesn't shows call  is hitting the Gateways when it is tranfered back to CUCM.
Looks like the issue is with the Netrix end.
Kind Regards
