IOS enhanced conference bridge doesn't register
acharyr123
Level 3
Level 3
But the problem i am facing is that: the conrefence profile is not taking the command " maximum-sessions" & hence the profile shows down all the time...
Plz find the sh run of the router & suggest...
Building configuration...
Current configuration : 7580 bytes
ip cef
ip domain name
voice-card 0
dspfarm
dsp services dspfarm
application
global
service alternate Default
class-map match-any CALL-SIGNALLING
match ip dscp af31
match ip dscp cs3
class-map match-any VOICE
match ip dscp ef
policy-map CE-EGRESS-EDGE
class VOICE
priority percent 33
class CALL-SIGNALLING
priority percent 2
class class-default
fair-queue
interface FastEthernet0/0
description MPLS IPVPN connection to Etisalat with IP 10.100.100.114
ip address 255.255.255.248
ip ospf network point-to-point
duplex full
speed auto
service-policy output CE-EGRESS-EDGE
ip rsvp bandwidth 168
interface FastEthernet0/1
description Life Sales Gateway Address
ip address 10.65.1.11 255.255.255.248
duplex auto
speed auto
router ospf 1
router-id
log-adjacency-changes
redistribute static subnets
network 10.65.1.11 0.0.0.0 area 0
network 0.0.0.0 area 0
ip forward-protocol nd
ip route 10.40.208.0 255.255.255.128 10.65.1.10
ip route 10.40.208.128 255.255.255.128 10.65.1.10
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/1/0
timing hookflash-out 50
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.40.64.5
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.40.64.6
mgcp
mgcp call-agent 10.40.64.6 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
mgcp profile default
sccp local FastEthernet0/1
sccp ccm 10.40.64.6 identifier 1 priority 1 version 6.0
sccp ccm 10.40.64.5 identifier 2 priority 2 version 6.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register RSVPdxbLS
switchover method immediate
sccp ccm group 100
bind interface FastEthernet0/1
associate profile 200 register CFB0024978C10B9
keepalive retries 5
switchback method immediate
switchback interval 15
dspfarm profile 200 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
associate application SCCP
shutdown
dspfarm profile 1 mtp
codec g711ulaw
codec pass-through
rsvp
maximum sessions software 10
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 9 pots
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/2/0
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.65.1.11 port 2000
max-ephones 42
max-dn 100 dual-line
dialplan-pattern 1 042337... extension-length 3
8 Replies 8
david-lima
Level 4
Level 4
Hi, check if you have enough DSP to configure the conference profile.
(show diag or show inventory)
All the best
David
chadlincoln
Level 3
Level 3
Your dspfarm profile is still shut down. Configure the maximum sessions and do a no shut on it.
Please rate if this helped.
Whenever i try to configure maximum-seesions under the profile it shows "0-0" as the session number & hence the profile is shut down...I have PVDM2-16...
Can u plz suggest..
Hi Acharya,
Your MTP profile is consuming all the DSP resources.
I don't know if you need software MTP resources on the gateway.
Try shutting them down and then try the max sessions for the conference profile.
It should work.
Cheers,
Bala.
Thanks Bala..I will try it & update
The MTP is NOT consuming any DSP resources, it's a SW IOS MTP
You already have 2 lines configured
service mgcpapp
port 0/1/0
service mgcpapp
port 0/2/0
So if you want CFB options are:
Do NOT use any line on it, meaning disable the above
Add another DSP.
HW CFB requires the WHOLE DSP. You only have 1 and 2 channels are in use.
If you don't know how to calculate DSPs use this
DSP Calculator
http://www.cisco.com/cgi-bin/Support/DSP/cisco_dsp_calc.pl
java
if this helps, please rate
java
Thanks Java..But can u plz expalin the below (that you mentioned in your post):
Do NOT use any line on it, meaning disable the above----What to disable?? (dial-peer voice 999010 pots
dial-peer voice 999020 pots)
Add another DSP---how to add another DSP? R u meaning to say add another DSP card into the Router??
Simply put, remove all the config for those voice ports and do not use them
Add DSPs = buy pvdm2
java
java
