Community Helping Community
191
Highlighted
paa Beginner
Beginner
IOS h323 gateway security configuration
Hi!
I have a 2821 router, 2 h323-ISP and UCM 7. Router works as h323-to-h323 gateway between ISPs and UCM. I'd like to protect my equipment from VoIP hacks. Config are simple:
voice service voip
h323
  emptycapability
  h225 connect-passthru
  h245 passthru tcsnonstd-passthru
interface gig0/0
description =To-ISP-1=
ip address 192.168.0.2/30
interface gig0/1
description =To-ISP-2=
ip address 192.168.1.2/30
interface vlan 1
description =LAN=
ip address 10.0.0.2/24
interface vlan 2
description =WAN=
ip address 99.99.99.1/30
dial-peer voice 1 voip
destination-pattern 1....
session target ipv4:192.168.0.1
dial-peer voice 2 voip
destination-pattern 2....
session target ipv4:192.168.1.1
dial-peer voice 3 voip
description =To-UCM=
destination-pattern 3....
session target ipv4:10.0.0.1
UCM route all calls to 2821 on address 10.0.0.2.
1) What protocols and ports should I permit troght 2821 (Is it enought to permit incoming RTP and h323 TCP 1720 only from ISPs address on ISPs interfaces?), how to correct configure firewall?
2) If h323-session from any outside address come to router on WAN interface (99.99.99.1), should call be placed ?
3) Can somebody recomend docs adout UCM and h323 security?
Content for Community-Ad
FusionCharts will render here
