IOS upgrade (C2900-UNIVERSALK9-M), Version 15.3 to support 7821,CP8821
Muhsin
I would like to add add multiple new IP phones models 7821 and CP8821 to the CME on ISR 2921 router, But current IOS/CME version does not support these phone models (flash:c2900-universalk9-mz.SPA.153-1.T.bin) , So I want to upgrade IOS on ISR 2921 router, I know that these series are EOL and no support from cisco. Which version IOS and CME should I upgrade to support these models. If it is CME 10.5 I need to upgrade to IOS 15.4.3M, Here is my question can I upgrade directly to 15.4.3 M from 15.3.1.T
@Jitender Bhandari @Deepak Rawat
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.3(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 26-Nov-12 14:52 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
EX-BS1-CME uptime is 2 years, 6 weeks, 6 days, 22 hours, 11 minutes
System image file is "flash:c2900-universalk9-mz.SPA.153-1.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco CISCO2921/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FGL16371083
4 Gigabit Ethernet interfaces
31 Serial interfaces
2 terminal lines
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
6 Voice FXO interfaces
1 Services Module (SM) with Services Ready Engine (SRE)
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
--More-- License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9
7 Replies 7
If these phones are supported in CME on this platform it would be listed in the CME documentation. Recommend you to review it.
Response Signature
Leo Laohoo
Yes.
The question is this:  Will upgrading the router IOS support 7821/8821?  No, because the router do not talk to those phones.  It is the CME/CUE inside that talks to the phones.  And unless the CME/CUE inside the router is upgraded, nothing will work.
The only way to get the 7821 to talk to an old CME/CUE version is to covert the phones to 3PCC/MPP.
For the 8821, I would not bother.  8821is a PoS.
@Leo Laohoo
Thanks for the reply,
So I can upgrade from 15.3.1T to 15.7.3M directly as well. CME versions are embedded with IOS,  So CME automatically upgrade with the IOS. If I upgrade to 15.7.3M CME becomes version 12.0. I hope phones 7821 and 8821 works with this CME version.
If the phones are supported in the CME version is listed in the CME documentation. Advise you to review it.
Response Signature
No.  CME is a totally separate component.  It is/will not "automatically upgrade".
@Leo Laohoo This is incorrect. CME is included in IOS.
Response Signature
Mea culpa.
Me confused with a different one.
