Walkthrough Wednesdays
451
@Syed
Participant
IOS Upgrade of SIP Voice Gateways
Hello All,
Greetings!
As part of best practice I am planning to upgrade sip voice gateway IOS , need your advise whether I the current IOS version is still supported or upgrade is recommended in this case.
Note: There are no problems with the current version now.
Router Model: ISR4431/K9
7 REPLIES 7
@Syed
Participant
if upgrade is necessary what would be the reliable version?
Wat solution you are having? IP TELEPHONY or CONTACT CENTER?
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
majorly IP telephony and we have a small contact center ( uccx )
Nithin Eluvathingal
VIP Advocate
What I recommend is take "Show Tech" and use it on  CLI Analyzer tool. it give you more details about the current version and if there is any problems with ur existing device and you can decide.
=>>>If this answered your question, please click "ACCEPT AS SOLUTION"<<<=
=>>>If you find this response useful, please mark it as "HELPFUL"<<<=
will try that and let you know how it goes
that did not help, looks like internet is needed to get result for 'show tech' output, but I ran this tool on an RDP machine which does not have internet access.
Any other possible way to validate this?
Yes, it connect with the Cisco. you need to enter the Cisco ID. but it gives u detailed report regarding the issues with the version which u are using and even it point out if you are not following any best practice.
you can take the show tech file and use it on a machine which has internet access.  use file analysis option. if you have "Show Tech File" install CLI on your machine and use the file analysis option.
Content for Community-Ad
Spotlight Awards 2021
