IP 8851 not Ringing
BrianThorpe2468
I have a Cisco IP 8851 that is not Ringing. Even when you hit volume up or down to set ring volume you do not hear a audible ring like on other phones. All CUCM 11.5 settings look right such as “device ring”. Any ideas?
BrianThorpe2468
SOLVED Turns out the Volume button was broken. When I replaced the phone it worked fine and I brought broken phone back, re-registered and I had the same problem.
George Sotiropoulos
Hello Brian,
Can you check under "Directory Number Configuration" -> "Line 1 on Device XXXXX" that the Ring Setting (on Phone Idle) is set to "Ring" (if this is not the default option in your implementation).
George
Hope the above helps,
gsotirop
Yes “Ring Setting” is set to “Use System Default” which most phones are set
as.
Could you change it to ring to check if it makes any difference?
gsotirop
BrianThorpe2468
