05-27-2022 02:40 PM
Good dear.
I am in need of changing the IP addresses of my collaborative infrastructure (CUCM, CUC and CIMP). Would you like me to help or indicate the proper procedure and if there is any risk in doing this procedure?
I look forward to your comments, greetings!!!
05-27-2022 08:16 PM
To run IP Addressing Change, you should note that if your infrastructure is going through a Firewall, you must duplicate all existing permissions for that new Network with the previous one, you must also consider the following:
Remember to support with a helpful and if this solves the problem select as a solvent answer.
05-28-2022 05:32 AM
This is well documented on cisco.com. Please see this document.
05-30-2022 11:54 AM
Thanks for the assistance @Javier Acuña and Roger
