IP Communicator 8.6
jj2212
                   Need to understand why when I'm on an IP Communicator call on line 1 and a new call rings on another line the connected call drops.  I'm not automatically connected with the ringing call I still need to click on the line button to answer the call.  I'm on IP Comm 8.6.2.0 on Windows 7.  Am I missing a setting somwhere?
testeven
What's the CUCM version you have? Does this happen when using the headset or speaker only?
Make sure the IPC version you are using is supported with the CUCM version you have.
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/8_5/english/release_notes/CIPC8x_RN.html
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
We are using system version 8.5.1.14900-5.  The data sheet says 8.5.1 or later is compatable.  It happens in speakerphone mode.
Can you try uninstalling and reinstalling the IPC? This sounds weird, does this happen when using a different PC?
Tere.
I unistalled 8.6.2 and installed 8.6.1 IP Communicator and I don't seem to have the same problems I did have.  As well as dropping calls 8.6.2 would not stay in headset mode, it would default back to speakerphone mode.  Thank you for all your help.
