IP Communicator Enterprise Scalable Solution for Vlan's
mdavis1969
Does anyone know of an entetprise deployable solution to use IP Communicator with Call Manager version 7.X or above to seperate the voice traffic and data traffic?
Here is the exact issue:
Need to use the IP Communicator on a Dpt. of Defense Network with IP Communicator.
Need to place the softphones on a voice vlan and the untagged traffic on the data vlan.
I cannot use the Trusted Relay Point as that does meet the US Dept of Defense Requirements.
I have one network card.
We tried using vlan's on the network card, but that requires a driver to be downloaded too each machine, and each machine to be configured individually. This is not scalable in large enterprise.
Any help is much appreciated.
Aaron Harrison
If you can't scale the configuration of the NICs, perhaps you can take a VPN approach.
E.g. configure a VPN client on the PCs which automatically connects to a VPN concentrator of some sort, and then bind CIPC to that (blocking other CIPC access from the standard/non-VPN connection).
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
