04-18-2012 04:07 AM - edited 03-16-2019 10:42 AM
When um trying to register my ip phone with CUCM its showing "Configuring IP"...for long tym..
What can be the problem while registering.
Thanks and Regards,
Harish
04-18-2012 04:32 AM
Have configured the IPC to use the correct ip addresses for the TFTP and the Call processors servers
Alex
04-18-2012 05:21 AM
Hi Alex,
Um giving CUCM ip as TFTP ip in IPC.
Thanks and Regards,
Harish
04-18-2012 05:06 AM
Hi Harish,
Are you getting the IP from the DHCP ? did you try giving the IP manually and check if it can be registered?
Abdul Sattar
04-18-2012 05:19 AM
Hi Abdul,
No um not using DHCP. I m giving ip manually.
Actually i have installed CUCM on vmware and by using gns3 um trying to register ip communicator with CUCM but its showing "Configuring IP"........
Thanks and Regards,
Harish
04-18-2012 07:00 AM
Can the PC running IPC actually ping the CUCM ip address (TFTP)?
I'd start there.
Ven
04-18-2012 09:09 AM
Hi Ven,
Yes i can ping from the PC where IPC is installed...
Thanks and Regards,
Harish
04-18-2012 09:17 AM
OKay. Let's run down the process.
If you can ping the tftp server (publisher) can you check the CUCM and make sure the appropriate services are running?
Go to the Unified Serviceability page, choose the server, and check to see tftp service is running.
Are there any other devices that can register to the CUCM?
Ven
04-18-2012 09:30 AM
Hi Ven,
Yes Ven tftp service is running its status is "Activated"....
n yes i have registered one gateway with CUCM and it got registered successfully....
Thanks and Regards,
Harish
04-18-2012 11:23 PM
Hi All,
Please suggest some solution for this...plzz...
Thnks & R's
Harish
04-19-2012 01:09 AM
Please go to your IPC, click on Menu (button next to the minimize button - on top right), go to preferences, go to Network, then check under device name which network card from your pc the IPC is using.
then double check if this is the correct configured MAC address you have configured on cucm.
