IP Communicator no incoming voice audio
chrisbuchner
Hi Experts,
I am using 8.6.6.0 Cisco IP Communicator.
External calls from outside when I answer them lets say my cellphone calls the IP Com. The external person can hear me but I can not hear them.
When I check the RX TX I can see RX is not picking up.
If I call them back we can talk normally no problems.
Environment:
IP Communicator has same IP as my Laptop which is different from my voice vlan IP subnet.
I am on the network of the CUCM.
VPN has same issue CISCO ANYCONNECT VPN.
Any questions please ask.
I am semi new to this but do understand enough about voice specially BE6000 11.5 cucm.
Rajan
Hi Chris,
Do you have any firewalls in the RTP path ? If so, its worth checking whether it's modifying the RTP ports in one direction where you are facing the issue.
You could confirm whether the streaming is between the right IP/ports, you could get a wireshark capture from the machine where IP communicator is installed and decode the RTP streams.
Rajan
Pls rate all useful posts
