IP Communicator on VMWare Fusion not working
ltrinh
Level 4
Level 4
I install & config IP Communicator 8.6.4.0 on VMWare Fusion 8.0.1 Running Win 7- the softphone register to TFTP server & seem like every thing working.
But when I make a phone call no sound (voice) come from the other side.  Only outbound traffic no inbound traffic.  Some one please help how to make it work?
Chris Deren
Couple of things to check.
Check Windows firewall settings
Run the Fusion in bridged networking mode instead of NAT as NAT will cause one way audio issues.
Hi Chris,
Thank you for your respond.  After I change Fusion to bridge mode the VPN not work & the phone no longer register.  Phone will register in NAT mode.  Any suggestion?
Hi Chris,
May be your reply is back to 2015 and i am posting my comments on Jan 2019.
Your suggestion from changing the Network setting in fusion from NAT to Bridge worked.
I have tried multiple options before searching google. Thank you again. on office network it worked. Let me check by connecting to VPN.
Hopefully it should work.
Gopinath U.
