Beginner
Ip communicator over wireless
Hello Guys,
Would like your help since i found very few documentation/support on the internet about that.
The guys from my company want to deploy 130 notebooks running over a wireless network.
We will not use ip phones but ip communicators as communications devices.
My question is.... Has someone alreday deployed this kind of architecture? I afraid that running voice over wireless will badly impact the quality of the calls.
Are there any best practices?
Thanks in advance,
Filipe Leite.
4 REPLIES 4
Highlighted
Hi Filipe,
It is possible to use IPC over wireless LANs, but you have to be very careful with QoS. If you refer to the SRND below, you'll see a section that talks about Wireless LAN Infrastructure.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/netstruc.html#wp1044317
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
Highlighted
Collaborator
The 7925 wireless IP phone deployment guide would be a good starting point for understanding the issues with running voice over wireless.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g/7_0/english/deployment/guide/7925dply.pdf
Obviously you will need to consider the other traffic to/from the notebooks running CIPC.
I have customers who successfully use CIPC wirelessly but not with the quantities that you are considering in a single office.
The BYOD guide at the link below may also have some useful content.
http://www.cisco.com/en/US/partner/docs/solutions/Enterprise/Borderless_Networks/Unified_Access/byodwp.html
Highlighted
Hall of Fame Master
Unless your wireless infrastructure is poor, I wouldn't worry at all.
However for effective use of the system, wherever possible, is better to have physical instruments rather than PCs, .
Highlighted
Beginner
Hi, I have a deplyment with IP communicators using CME and they are using analog lines. The problem is they complain a lot regarding the performance of their IP communicators. The AP that they are using is a 3502. It's a small office and all of them use wireless and they all connect to this 1 AP. For me, a physical phone is still better since you can separate the voice traffic from the data traffic unlike in a softphone wherein the data and voice are shared in the wireless infra.
