Beginner
IP Communicator Problems
Have just installed IP Communicator onto Windows 2000 workstation but it doesn't load !!. I get a splash screen after running the audio tuning wizard andd there it hangs.
Does anybody have any ideas....please ?
scott.
Rising star
Re: IP Communicator Problems
When you launch IP Communicator and get the slash screen, right click on the winow and select Preferences. Here, make sure that under Network Tab, you have the TFTP Server info updated
Beginner
I have verified that information is updated and correct as that was my first suspicion
Rising star
Can you run Error Reporting Tool and attach the output to this post ?
Beginner
Output from error reporting tool - it doesn't look good.
Highlighted
Beginner
It doesn't get that far !!, I have a white box with a picture of a bloke using communicator on a laptop and thats it, it goes no further.
Beginner
Check for any ACL on CCM VLAN... Make sure that your laptop passes through the ACL and can access CCM.
Sheeraz
Beginner
This is from a desktop in my local lan - No ACL's apply
Rising star
looks like we have missed couple of things,
Version of CIPC
Do you have Full Administrator rights on this machine ??
Beginner
Version is 2.0.2
Yes local admin rights on Win2K workstaion in question.
Scott.
Contributor
Go to your Eventviewer and post any error you are getting at the time when you run CIPC.
Beginner
Nothing in Event Viewer in any catagory
Scott.
Contributor
Ok then run a sniffer (ethereal) see if CIPC is crashing before or after connecting to the Network.
Beginner
Ask the Expert- Firepower configuration & troubleshooting
